spec help
Anytime you over clock cpu/gpu and ram you see performance increase, the trick is balancing many factors such as cooling and case air flow. Doomspeed is a lot more knowledgable in these areas. but with something like the
YOUR BASKET
1 x Noctua NH-D14 Dual Radiator CPU Cooler (Socket 775 / 1150 / 1155 / 1156 / 1366 / AM2 / AM2+ / AM3 / FM1 / FM2) £62.98
Total : £72.88 (includes shipping : £8.25).
You would be able to over clock cpu fine (choose this as i know its only 160mm tall) others such at mount doom and that could fit but again Doomspeed will keep you wright :)
Ram over clocking is way above my knowledge i noramly just get the speed i want eg 1600,2333 and so on
That at £72 is stretching my budget tough..
That is a nice cooler for the money and should keep your cpu nice and cool not sure how much OC'ing head room it would give you tho. wait for doomspeed the
YOUR BASKET
1 x Thermalright Silver Arrow SB-E SE CPU Cooler TY-143 Fans (Socket 775 / 1150 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) £59.99
1 x Alpenföhn K2 Mount Doom CPU Cooler (Socket 775 / 1150 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) £59.99
Total : £130.48 (includes shipping : £8.75).
are both fine coolers but alittle taller which may or may not fit im not sure again id deffer to those with more knowledge on that what is your top budget for a seperate cooler?
They are nice and come with a 90 day warranty. i didnt recommend it as they are pre order and not sure when theyll come in are you building now or can wait?
Nobody has commented that the CPU doesn't fit in the board? :)
Wow, i can't believe that, there was obviously other things bothering us more. Well found. :)
There aren't any suitable micro-ATX boards for the CPU unfortunately. You could look at one of the smaller ATX case, like this:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-107-CA
That would let you use a similarly priced motherboard in the system, e.g.
http://www.overclockers.co.uk/showproduct.php?prodid=MB-385-GI&groupid=701&catid=1903&subcat=2046
I can't believe that, are AMD that short-sighted? Not decent mATX board the intel side is PLASTERED with Great affordable mATX motherboards and AMD can't commision one?
It'd be a shame to change the 350D..
I dont want to change my tower, so your telling me theres no suitable motherboard for this tower?
If you absolutely want micro-ATX, your choice is an FM2 AMD processor or an Intel board+CPU.
Apparently the board manufacturers think there's no demand for micro ATX or mini ITX FX boards because it has no integrated graphics.
