So by looking at that then comes into my mind of two options for the build if i'm correct.
First one is to go with a Corsair 350D along with Intel processor and micro ATX which will outpast my budget?
OR
to go with a midi tower and ATX board with AMD3 processor which will be slightly cheaper?
hmm I need to start measuring my desk space before chossing either one then..
Which would you go for?
OR
The card is good, for a little more you could get the 7870 which can be overclocked and give the 7950 a run for its money.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-185-MS&groupid=701&catid=56&subcat=411
Made slight change.
this is the spec for gaming and also accounting for limited space.
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM £179.99
1 x MSI HD 7870 Black Knight 2048MB GDDR5 PCI-Express Graphics Card (R7870-2GD5T) £167.99
1 x Corsair Obsidian 350D Windowed Micro ATX Case - Black £86.99
1 x **B Grade** ASRock Z77 Pro4-M Intel Z77 (Socket 1155) DDR3 Micro ATX Motherboard £77.99
1 x Corsair Builder Series CX 600w Modular '80 Plus Bronze' Power Supply (CP-9020060-UK) £62.99
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £43.99
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished Unit - 90 Day Guarantee £39.95
Total : £673.98 (includes shipping : £11.75).
what do you guys think?
Hmm, ok Doom
You see the one you suggested earlier on; MSI motherboard , does that support x5 fans?
I will need 5 in total, that is 2 in the front, one at the back and two at the top of the PC case but then I'm going for H100 for the top. So i will need the three fans to be connected to the board?
