i got a 1080p 40" sammy M87. cant falt it. would reccomend it. u can get it for around 700 now.
Everyone raves on about the Samsung M87... But I don't really think it's that great for SD.
Once it has been setup correctly it is good with SD to be honest, out of the box it looks awful no matter what source. There are plenty of settings on avforums.
Mp4 - Yep thats the one, its a great looking tv thats for sure
I had the m87 when it was lauched but due to faults Samsung couldnt fix at the time I got a refund and now have the f86 (which uses the same panel). I used the settings here... http://www.hdtvtest.co.uk/news/2007/04/22/samsung-le40m86bd-settings/ but I had skyHD which uses HDMI so the settings will be a little different for you. Its worth having a look in the huge thread and try a few different versions out to see which you prefer, as all viewing environments differ.
I have only ever used the xbox 360 hd-dvd and the ps3 for blu-ray. I have played dvd's though both so they will have been upscaled by the player. If the dvd player has a component connection you should be able to get a decent picture with the tv doing the work, anything less than that such as scart or composite isnt really going to be as good. But as I said I have no experience of this on this tv so results may vary, hopefully someone can post who does use a dvd player with the tv...
Going to use it for TV / and for gaming (Wii) thats about it
this the one?
http://www.samsung.com/ie/products/television/tftlcd/le37m87bdxxeu.asp?page=Features
yummy
Sorry to hijack guys buy I'm going for the 40" Sammy and I'd like to know which would be a good bracket and maybe the cheapest place to buy?
Thanks
