My parents asked me to get them a cctv camera to cover their car.
The car is around 6 meters away, should I be looking at cameras with lenses of 6mm ?
I have a 7608 so not sure if it's the same but I have two HDD in mine a 2 and a 3 gig -
Doing a quick google you should have two sata bays and each will take 6gbit
Hope it's this one. https://www.hikvision.com/en/Produc...Turbo-HD-DVR/Turbo-HD-3.0/DS-7208/7216HGHI-F2
AAAARRRGGGGHHH Help
Our Cafe was broken into sunday night. We've got the little scrote on CCTV but how the hell can I DL the footage.
Its a Hikvision set up with ds 7208 DVR and 8 cameras.
I have the hikconnect app and IVMS 4200 latest.
What the and where the hell is everything.
Ta
Matt
Boot up IVMS, go to the "remote playback" tab.
At the top left, there will be a start / end time. Make sure the date you want footage from is between those date/times. It defaults to the last 7 days, so it should be there.
Next, drag appropriate camera from the panel at the left into one of the display windows.
The easiest way to download is by time, so play it back and note approximate start / end times.
Right click the playback window and choose download.
Choose the download by date tab at the top, check the duration 1 box and the input the start and end times into the coresponding boxes. You can use the calendar icon or enter manually.
Click okay.
The footage will end up in C:\ivms4200\video and the folder name will be the date and time in a long string of numbers. There should be a few .mp4 files and some .jpg thumbnails.
It should be playable in VLC or media player classic etc.
I'm the superuser..
Odd aint it..
It appears I have to record the footage then I can save it..
Can you access the Web UI?
It can be indeed, the amount of times I've dealt with the off-load and handling with the police is remarkable.yes
I'm in via webui
Jeez what a ballache
