Hi,
Are many people using Blue Iris instead of an NVR?
My current set up consists of 6 "proper" CCTV cameras and 3 garden wildlife IP cameras...
All of these are set to record direct to disk in Blue Iris and I don't think I have any hardware acceleration in use.
Blue Iris is on my main PC with the following specs...
This is the PC that I use for most other things so its not dedicated and I never really intended to keep BI on here for the long term as its also quite power hungry for 24/7 use. I've been given the following for free....
This is quite a nice small form factor PC so I can hide it away somewhere and it should have lower power consumption. It does only have one drive bay though so I'd probably put in a 4 - 6 TB WD purple drive.
Any thoughts on moving to this machine? Will the 4th gen i3 be too under powered?
The Blue Iris website indicates that a 3rd gen i5 with 6gb is the suggested minimum for a small (6 camera) system and a 4th gen i5 or i7 with 8gb is recommended.
So I think that the CPU is the weak point here, rest of the spec seems okay and the one drive bay is slightly limiting but of course the machine was free. The alternative will probably be to leave it where it is for now rather than spend out on another machine.
Thanks for reading.
TLDR: i3 4130 haswell for 9 direct to disk steams in blue iris - Y/N?
- 4 x Hikvision DS-2CD2335 - 2048*1536, 25FPS, H265, Highest Quality, Up to 3072Kbps - Full Time Recording
- 2 x Hikvision DS-2CD2555 - 3072*2048, 20FPS, H265, Highest Quality, Up to 3072Kbps - Full Time Recording
- 3 x Generic Wildlife Cam - 1920*1080, 25FPS, H265 - Record on Motion Only
Code:
i7 3770 quad core @ 3.4ghz (Ivy Bridge / 3rd Gen)
12GB DDR3 800Mhz
2TB Seagate Barracuda Sata 3
AMD HD 7800 1GB
Win 10 Pro
1000w
Code:
i3 4130 dual core @3.4ghz (Haswell / 4th Gen)
8GB DDR3 800Mhz
500GB Seagate Barracuda Sata 3
Intel HD Built In Graphics
Win 10 Pro
240w
Thanks for reading.
