Anyone tried out Verkada yet? They seem to have a really neat looking solution too
Prices look extortionate.
Also call me old school but corporate CCTV systems (and particularly access control system) should remain local, sitting behind your internal firewall/VLAN.
Yes I can still remember rotating VHS tapes and storing them in fireproof safes.Also you can't hack a coaxial CCTV system.
Don't get me wrong, cloud technology has its place but the need to throw every bit of technology onto it just seems like jumping on the bandwagon. Maybe it's the thought of less control of one's data, ongoing subscription prices and internet outages that are holding me back.
Less control, not no control.
Also not every country complies with GDPR/DPA.
I've scanned through the posts and there's so much to take in - If I start with 2 external cameras and an NVR what should I be looking at for a budget of around £600? Needs to be expandable (add a few more cameras if needed) and allow me to access video from wherever in the world. I was looking a t a couple of Eufy cameras and a doorbell but now wondering if wired is a better option.
Many thanks
@BogEyes Something like this for £315......
https://www.amazon.co.uk/Reolink-Se...CH-5MP-POE-NVR-4-Bullet-Cameras/dp/B01C5JE3DS
is what I think of with a Reolink kit and whilst there are Hikvision and Dahua kits that could be considered by some to be preferred the Reolink does give the impression of offering great value.
How would you consider it to be less flexible for your future needs, the NVR in the above has 8 POE connections...? Was there other things that you did not like and which ones did you buy..?
Something "decent" with a budget of £300 - how many cameras would you want...?
Perhaps @WJA96 can offer some solid advice, and he has already listed some typical prices of Dahua kit a page or two ago to give you some idea.
Best of luck.
