With a higher number of cameras it's best to use an NVR, as you will quickly use up storage capacity on your PC.
Thanks - didn't consider this at all. Emailed them and within 24hours I had a code for 50% off the full version.Did you try emailing them? They might sort something out for you
Doing some research for my Dad into securing the house.
We want 3 outdoor cameras to record / stream etc & a video doorbell as well.
What’s the best package to get or is it better to get the cameras on one system and a simple ring / nest doorbell type thing to have as the doorbell separately?
Recommendations would be appreciated as I’m getting confused!![]()
I still cannot read a number plate on a car across the road.
Anyone know the answer to this one please? Hoping to upgrade my CCTV asap. Currently have Blink, wanting to change to a 24/7 system with decent night performance. ThanksAre there any UK suppliers of HikVision that sell to the end user, without the somewhat ‘grey’ issue of a trade sale?
Finally after 9 months I have had my Hikvision system fixed.
Had two more cameras but PIR - had front colour in dark one moved from front to back - So two PIR ones at front -gable and garage door - two colour in dark at rear - the two I was worried about are on porch -one facing forward and one back and are the old cameras with passwords in I couldn't quite remember but they popped up and worked straight away.
The only problem I have and pointed out is the 4 new cameras (4mp) are a bit pixally when you zoom on something - he agreed about that and I told him I was going to buy a new 4k monitor to see if it improves.
The new NVR is M2 model
My Benq monitor is so old they are on sale second hand for £20
Personally I don't think it's the monitors, I think it's the cameras, so a 4K monitor will make no difference.I have spent 2 days looking for a 4k 23/4" cctv monitor and can't find one so looked for PC monitor then got confused by all the tech stuff.
The cameras are DS-2CD2346G2-1U
