That's good advice, wouldn't have thought. They are connected to a synology 916+ NAS so i'll check if a 4k will run on it. Is the reflection at night down to the IR bouncing off reflective surfaces?
The reflection at night is down to the IR bouncing off reflective surfaces such as number plates or sides of cars which is what I am trying to combat. I will tinker with switching the night mode off and IR to see how the footage looks.
The only other annoyance is Hikvision not working with OSX at the moment. The phone app is lacking for anything other than quick playback and notifications.
I need to install a Windows VM to access anything suspicious with smart playback.
I had this issue, could only be solved by switching to using a browser called SeaMonkey, its actually been quite convenient having a separate browser dedicated to my CCTV
BlueIris is the way to go if you don’t want to purchase a standalone NVR.
The 2332 turrets mentioned a few posts ago are not low light. They are pretty rubbish at night tbh. The 2335 turrets are low light and are in a different league. Shame they are apparently being taken of the market. There is an 4K low light cam being released shortly which I would like to test but a figure $1000 is a turn off.
IR light will cause problems on number plates unless you are reading the plate at an angle or better to turn off IR and use in daytime mode but tbh, unless you have a low light cam with a motorised or a high mm lens, I wouldn’t waste my time to read plates at night.
I know others have asked already but anyone spec me a 2 camera outside POE system and i assume sort of hub/nvr for it ? And im guessing your all into alarms as well and although we have an older wired system atm im looking at getting a wireless system for more coverage withought running loads of cables . Yale seem to be top but looking at other options
I can recommend Visonic@agw_01 Tnx quite like the look of the Ricochet setup. Sadly we have done a load of decorating and i really dont want to start lifting floors etc
I've been quoted £1k for supply, install/fitting of a Dahua system; 4 x external domes (4MP); 1 x PoE NVR and associated cabling.
I've been quoted £1k for supply, install/fitting of a Dahua system; 4 x external domes (4MP); 1 x PoE NVR and associated cabling. Does that sound about right these days? Also, any thoughts on Dahua? I had previously settled on Samsung Wisenet for self-install, but the specialist recommends Dahua instead?
