Don't realy like on ear headphones so ill pass on these thanksSennheiser HD25 are worth considering. Good portable headphones and they isolate outside noise well.
Sony MDR-1A if you like lots of bass, decent mids and highs with a little sparkle
or
Audio-Technica MSR7 if you prefer much less bass, decent mids and hot highs with loads of detail.
On ear style so no but thanksNAD HP50, if you can hack the slightly odd headband.
hm... dont like the look of them are they same/worse/or better than AT MSR7 ?You can pick up a pair of 2nd gen Momentums for that - they're well worth considering.
HD598 closed edition is great too - I believe they're the 598 CS?
Agreed. Solid as a rock with good sound. Personally even for on ears they're pretty comfy.Sennheiser HD25 are worth considering. Good portable headphones and they isolate outside noise well.
Which one i should go for 32ohm 80ohm? DOnt this fiio will be able to push 250 ones?DT770 if you don't mind wearing something a little bigger in public.
Any difference in sound between 32ohm and 80ohm?the 80ohm version will have a 10ft straight cable and the 250ohm version has a curly 10ft cable, which can't be swapped out, whereas the 32ohm is made for portable and has a 4.5ft cable
They look interesting, one thing puts me of and its a cable. Will have to decide beyer 770 pro ATh msr 7 ot these. Got some reading and YT to do nowSony MDR-7506. Use them at work, they're great. I did however replace the pleather pads with velour.
