Straight to the point. It will be used primarily as a family car, and potentially used as a private hire later vehicle later on (think part time Uber).
Requirements are
2015 or newer.
Hybrid.
Budget: £15k Max.
Keep for 5-7 years.
High mpgzzz
I have looked into the Lexus Ct200h which seems to be a more fancier Prius, and I've seen plenty being used as private hires.
Is there anything else which I should consider?
EDIT: I have looked at diesels also, such as a the Mercedes e300 hybrid, but have read of some having issues with the batteries?
Alternatively I have also considered a diesel such as Octavia VRS/Passat but not sure if it's worth the risk now with how the government are banning away with diesels.
Requirements are
2015 or newer.
Hybrid.
Budget: £15k Max.
Keep for 5-7 years.
High mpgzzz
