Calling all ye pen pushers.. I mean, experts on quality pens. I want to white paint over half a dozen pinhead and nailhead size brown spot stains on the front of a white v neck t-shirt type top I have. I've washed it twice with Vanish and also some of that bleaching agent oxi cleaner stuff which has bleaching agent but these stains won't come out. I'd thought of fabric markers but now I'm thinking a permanent marker pen would do the job. The best one I've found so far is a Pilot White marker, extra fine point approx 2mm nib. It's only £3.20
Reviews are generally good, slightly mixed, but one person said the tip worked it's way loose and fell out and another said the paint was a bit thin and needed a few coats. So can anyone recommend a trusted brand or particular pen they might have used, with fine tip, permanent ink, in white, where the tip doesn't fall out and the paint is not too watery?
