- 9 Apr 2012
You can adjust the level I run mine at -2 which is for me is great. Unless you don’t like your neighbours then you can crank it up and there is also a bass enhancement option too.
There is also an option to disable the sub and use the soundbar to create the bass which is far more neighbour or night time friendly if you need to limit the bass. You can pretty much tune for all situations.
Can anyone adjust the level? I thought there was a night mode that basically did the same thing.
