Budget deck go Rega
Mid price deck Michell Gyrodec
High end go SME
This years What HiFi awards:
Best Product: Rega RP3/Elys2 £550
Best turntable up to £400: Pro-Ject Essential II £200
The Rega RP1 is also an excellent budget alternative.
You say you don't have a budget Easy, a deck isn't the only thing to consider. Cartridge and phono stage are as well.......................so what's your total budget ?
Surely I could get decent results for 300?![]()
If you want good sound for £200 buy a SBT because good sound from a TT add another 0 imo.
Well, put it like this, my cartridge cost a lot more than £300.
Yes, you will get results for £300..............................If they are decent or not depends on all sorts of things. Not least, on how much you love Vinyl and how many records you have. Along with the question, do you intend adding to your Vinyl ?
