- 11 Sep 2013
TBH, I've tried quite a lot of torches and find that a 90º one tends to work best for most situations, particularly as they can be clipped or magnetically clamped to surfaces for when you need hands-free or when the red light features are necessary.Good question. I'm thinking a bit bigger than that, can't you read my mind?!
Also, a proper handheld, not a 90 degree head/chest torch.
So how big, exactly?
Are we talking an extra inch longer or greater girth, or are you more interested in a Maglite style?
Most dimensionally bigger torches don't offer much in the way of longer battery life and they tend to have similar brightness. Those that are brighter don't do it for long, as they automatically step down to avoid overheating. For that you're after the handheld spotlight style, which comes with a shoulder strap because it's that big.
I've found a few examples that might fit your spec - The red light requirement rules out a lot of other options, and some of these are discontinued, but for now we're just looking to see what sort of thing ticks the boxes...
Fenix TK47 Flashlight | Fenixtorch.co.uk
Fenix TK47 Flashlight. Max output 1300 lumens. Uses 2 x 18650 batteries. UK Supplier. Next day delivery available.
Fenix TK26R White, Red and Green Compact Tactical Torch
Nitecore P18 Tactical Torch with Silent Tail Switch | Nitecore.co.uk
Nitecore P18 Tactical Torch. Includes IMR 18650 3100mAh battery and detachable pocket clip. Cree XHP50 HD LED with separate red auxiliary light. UK Distributor. Next day delivery available.
Fenix SD20 Diving Light - DISCONTINUED
Fenix SD20 diving light is specifically designed with the diver in mind. This flashlight is waterproof up to 100 meters and has a max output of 1000 lumens.
www.fenixlighting.com
JETBeam Jet 1M Guardian Flashlight Review - ZeroAir Reviews
The JETBeam Jet 1M Guardian flashlight offers a few white modes along with red and green, and most unusually, can run one 18500! Read on!
L17 Tactical Flashlight
L17 is the best long-distance flashlight in the same size. Using the smallest LED core with high power. The best choice for hunting.
www.acebeam.com
