Olight marauder mini. You won't need anything else.Anything similar or that can best an Acebeam L35 2.0?
I wanted a practical light i can carry in my pocket. I looked at the mini, its a chunky boy!Olight marauder mini. You won't need anything else.
Mix of both, I ordered an L35 2.0. Can always sell it i guess if i find something else.Do you want a dedicated thrower or a mix between throw and flood?
These are two of my favourite lights I've got this year, the Surge and Stellar. Both pocketable, 21700 and pack a punch for their size.I wanted a practical light i can carry in my pocket. I looked at the mini, its a chunky boy!
I dont even why i like torches, i live in a city center![]()
Anyone? Been looking at the OLight Baton 3, 4 and Turbo, they seem to be a similar size. Anything else I should look at/consider? TaSo I've had a few of these over the years, this particular one for some time, as you can see! What sort of thing should I be looking for if I wanted something a bit brighter, robust but the same size? I really find the 14500 cell handy as I can keep a spare on me and swap it out when the first one runs out of power, or should I just replace the two 14500 cells and get another of the above? It's starting to get a little tired, keeps changing between modes by itself (a low/high feature is handy to have as well). Run time could be better though. Are Keeppower still a thing? Ta
If you like 14500, the Lumintop Tool AA is a favourite. Uses 14500, but can also run on AA if you need to, whereas most AAs cannot take a 14500.Anyone? Been looking at the OLight Baton 3, 4 and Turbo, they seem to be a similar size. Anything else I should look at/consider? Ta
As above really can’t go wrong with a Baton 4 Premium Kit with the case. Also you can get a Perun 2 mini to charge in the case as well. Also the case can be used as a small power bank 5000mah for emergencies.Anyone? Been looking at the OLight Baton 3, 4 and Turbo, they seem to be a similar size. Anything else I should look at/consider? Ta
I have the Baton 3 Pro Max and love it. Good light spread, compact and solid. And turbo mode is amazing.Anyone? Been looking at the OLight Baton 3, 4 and Turbo, they seem to be a similar size. Anything else I should look at/consider? Ta
