What case/coolers are they for? what size do you need?
Also why do you need 7?
7 seems a lot and more than likely over kill
BeQuiet Silent Wings 3 are my choice of fans at the moment
There are 5 of them in my system of varying speeds but only 3 of them are case fans
I was thinking more as the case doesn't have the usual route of flow for air... How many would you recommend in the Antec P120
Not personally used it, but looking at the website and suggested airflow - probably 3 intake fans at the bottom, and just 1 exhaust fan at the rear
I've used these in 2 of my PC's now - cheap, fairly quiet, and seem to move a decent amount of air:
My basket at Overclockers UK:
- 1 x Arctic Cooling P12 PWM PST Black Fan - 120mm= £5.95
I've got a mix of Corsair LL120's and Deepcool RF120's in my machine and both are pretty much inaudible and push a decent amount of air.
Oh that's good to hear, are the LL fans RGB or am I thinking of something else? What case do you have?
Sorry, correction, the Corsairs are ML120s, so are fixed red colour and don't need the whole propriety Corsair RGB system crap, they're on the radiator. The 3 deepcools are the main system fans.
I have a pretty aggressive fan profile, they all run on minimum duty cycle unless I'm gaming, then they'll all ramp up if need be. You'd hardly know the machine was on when browsing![]()
Are PWM worth the extra few quid over non pwm?
That looks really smart mate, I will take a look at the Deepcool fans you've mentioned.. What program do you use to adjust the fans speeds?
Sorry to jump in, just noticed you have the same motherboard as me and curious as to what fan profiles you use? I've got mine setup but there is almost an infinite different ways of doing it.
My case fan profiles are completely flat at 20% for 10C, 20C and 30C and then the fourth marker is 100% at at 42C based on system temp for example.
Did you know you have to add 20C to the CPU temp in the BIOS?
