any reason you want to change the mech? looks ok from here?
that chain tho!
I'm taking Johnnys advice and giving it a good clean and lube.
Thanks Vent
that chain tho!
Those brakes will fit and once set up are pretty good brakes but the shimano deore hydraulics are a similar price are they not?
Further up I linked to Avid BB5 disc brakes and the cheapest I found was £29 and the Avid BB7 was out of my price range however I've seen this rather excellent deal for both front & rear calipers + rotors - http://www.ebay.co.uk/itm/191078659...49&var=490269940792&ssPageName=STRK:MEBIDX:IT
I rang the number and he said they would be a direct replacement.
Any thoughts or go for it?
The £20 difference shouldn't be an issue. Hydraulic disc brakes really are that much better to use and require far less maintenance. With most cable discs you need to constantly adjust the pad clearance, with most hydro discs that's automatic. They're generally just fit and forget until you need to change the pads.
Far be it for me to agree with Dimple but I would also be a bit worried about changing over from cables to hydraulics. Hydraulics are definitely better in many ways but the ease factor of cable-actuated disc brakes is definitely an important one.
This is very true and having recently made the move I really agree that the reduction in maintenance is absolutely massive.
