RIght...... just had new Vaillant Ecotec Plus 831 and all new radiators installed.............but guy who installed said existing 8mm microbore would be 'fine' (despite my concerns), anyways......now I find less than stellar performance, even boiler going into anti cycle mode and rads take a while to heat and possibly colder at bottom etc......tinterweb tells me 8mm microbore esp with this boiler can cause issues.....this in mind I am considering embarking on replacing the 8mm manifold and pipes to and from rads........
My plan is cut the main 22mm copper run and use 15mm speedfit to rads.
- Is this ok/feasible to do?
- What would be the best method? (speedfit manifold?)
- Do I need collets(?) to connect 15mm speedfit to my existing Danfoss TRVs and lockshields at other side.
- What are the caveats?
