As an update to my numerous DIY adventures this summer........ Central Heating now seems ok I've moved onto bathroom
, after much wailing and gnashing of teeth getting nails out of floor it was time for the bath to come out.........no prob there except a cast iron bath is stupidly heavy.....anyways that didnt give me much hassle.............the compression fittings on the other hand lol.........the one on the right blew off like a geyser, I HAD noticed that the original pipes were 3/4 and i DID use 3/4 olives (some bodgers use 22mm but way to dodgy for an amateur like me), anyways as far as I can tell......I put the olive on not far enough and the wrong way up....AND lots of youtube vids tell you 3/4 of a turn should be enough, imho not the case when using brass olives on to an old thicker walled 3/4 pipe.........anyways no damage done, bout half a basin of water all over the place but I sprinted to the stopcock like Usain Bolt
