And the usual BUS rules apply, so you only get the £2500 grant for A2A if you also remove your gas boiler at the same time.
It's realistically not going to apply to the vast majority of households getting AC installed.
I suppose you could also heat the house using them but it doesn’t tend to work as well as a gas system, nothing does. I'd rather do that than get a normal heatpump though.
I wonder if you moved in to a house which needs the boiler replacing anyway, you get the grant and install AC. Then replace the gas boiler
