Split Air con
I'm after some advice for aic con in a single room
7m x 5.6m x 2.6m. 2 small windows that are likely to be closed off and very well insulated.
How does his one look?
I’d want to get a black internal unit, but as an opening point for discussion that's a suitable one.
Educate me please.
Educate me please.
If the room has small windows and is well insulated as you say, then it's way too much capacity. Like 2x too much. Probably look in the 3.5 kW range at a maximum, and even that is probably a bit generous.
