Am I right in thinking that during the winter you can use the AC system as a dehumidifier? That would be a huge bonus as we currently use one in the cold months.
Looking at getting 2 rooms done in my home with a single outdoor unit. Had one quote for Mitsubishi kit for £2.8k. Wasn’t fond of the bloke that quoted so probably won’t go ahead with it.
I have some questions if you guys could help?
Do I need to get planning permission for this?
Can anyone recommend a supplier/fitter in the North Hampshire area?
Are there any must haves on a modern system? I want to be able to control them from my phone both in and out of the house. I’ve been told I need to get ones with variable inverters, but I think they all do now. Any other must have features? Thanks.
unless it's some very fancy units that price is extremely highLooking at getting 2 rooms done in my home with a single outdoor unit. Had one quote for Mitsubishi kit for £2.8k. Wasn’t fond of the bloke that quoted so probably won’t go ahead with it.
The quote was for:unless it's some very fancy units that price is extremely high
Yeah the guy mentioned this, but said it's only a difference of £100-£150.The single condenser will put the price up however it’s neater with just the one
£1k fitted for what ?Should be around 1k fitted for each unit. Perhaps a little more down south.
Loving ours.
Loving ours.
might have to look at draping some towels over the outside of the bedroom windows to try and stop all sunlight getting in!Looking at the forecast for Sunday-Tuesday, I just want say to everyone with air-con at home: damn you all
We're definitely going to look at a permanent install but priority right now is saving for a wedding and honeymoon so it'll have to wait a couple of years. I've cadged a dehumidifier as a small attempt to make things a little more comfortable this weekend but I'm not sure it's going to do much with a south-facing bedroommight have to look at draping some towels over the outside of the bedroom windows to try and stop all sunlight getting in!
So if I got a load of cardboard, coated one side in foil and taped to the windows (foil outwards), it should reflect a lot of the light and heat?Foil is your friend![]()
the price will vary depending on which brand you have installed.
