SSD Help
Yea I tried the HDD and it lets me boot into that, but I have to change the thing from ACHI to IDE
Heres the AHCI setting
http://i.cubeupload.com/QbFKxW.jpg
My HDD shows up under
'Hard drive BBS Priorities' and under 'Save & Exit' I can choose to 'Boot overide' with the hdd
Reinstalled Windows 8, not sure if MS have gave me the correct version though, installed a lot of stuff so far and restarted a couple of times and its fine except windows 8 keeps failing on a certain update.. :rolleyes::mad:
Might just turn them off until SP1
EDIT:
Yea apparently my key can only be used on upgrade versions and not clean install.. yet when I installed it last time it accepted the key.. I hate Windows.
EDIT 2:
Incase someone finds this on google, this problem is rare it seems, a motherboard driver must have hurt my windows install or something, not sure how to boot safe mode windows 8 and the repair off the OS disc didn't find any errors so I ended up reinstalling windows 8 and my gfx card drivers, haven't installed mobo drivers incase it messes up again, installed windows updates, applied ssd tweaks and restarted multiple times without error :)
