SSD problems driving me mad
17 Jan 2012
OK I think I'm finally getting somewhere with this SSD problem.
I need a second drive for my computer specs as follows -
AMD Phenom 2 X4 850
SSD - OCZ Agility 3 - Firmware 2.15
Gigabyte M68MT - No AHCI
Windows 7
After three attempts, I'm stuck as to what to do next.
I'm running the drive as IDE and after I am able to install all my programmes, the drive starts playing up whilst using Windows 7.
After a reboot, the computer will not boot from the SSD.
Do I .....
a) Keep trying with the OCZ - I could try RAID instead of IDE but I don't understand how to set it up.
b) Try another SSD (perhaps an M4) and try that, I've heard they are more stable.
c) Give up and get a HDD instead?
I'm a bit fed up with this all now really.
Thanks folks.
Have you connected it to the first SATA port on your board? Have you tried using a different SATA port and/or controller? (will be a different coloured port). Also check your boot priority in the BIOS.
whats the exact model name of your motherboard? i did quick search and it came back with nvidia ahci pre install drivers for win7??
I installed those already. I got a feeling I.messed up though. I followed the guide to change a msahci setting in the registry to 0. I thought that would enable ahci as I couldn't find it in the BIOS settings.
You'll still have to enable it in the bios. It should work if you set it to Raid.
using latest bios? it should be under onboard or integrated perepherals look through each page or read manual to show you where to set to ahci
