If it works out cheaper then go ahead. Just make sure you're using the two red native Intel SATA 3 controlled ports for both drives. Annoyingly though, Asus decided to colour the crappy Marvell controlled red as well, so you will need to check your motherboard manual which ports are what.
RAID is controlled by the BIOS anyway, so for the RAID packs you will have to set it up yourself. If you're not planning to RAID then just leave the BIOS option to AHCI.
Call me blind but I can't see the RAID packs on OcUK anymore?
EDIT: Found them, they was in another section silly me
. It's about £20 cheaper so go for it!
