SSD Showing as USB?
7 Jul 2009
Wiltshire
So, having just installed a SSD for the first time and whilst going through a clean install I've noticed that the SSD is showing up as a USB and I have the option to "Eject" it.
Should it be appearing as a USB, I mean, is this normal?
If not, what do I do to remove it from there so I don't inadvertently "Eject" it?
Thanks
Wouldn't worry too much, GPU's are starting to appear in the 'eject' list from time to time these days.
My SSDs appear under the "safely remove hardware" option.
I have 2 x 850s on windows 7 and they are both under there, i think its for hot swapping options supported by ACHI, nothing to worry about.
