- 11 Jan 2011
Hi, i planned on overclocking but after doing some tests to make sure my current system is running stable at stock speeds i think something is wrong.
ok so first of all i run the intel burn test which showed
intel burn test 1st attempt - stress level standard run for 5 mins then fail
i tried
high stress run for 20mins fail
Max temps show
core1 - 51
core2 - 51
core3 - 54
core4 - 56
2nd attempt - high stress run for 5 mins fail
then i run OCCT
occt
1st attemps after 2 mins - fail core 4
2nd attemp after 15mins - error detected on core 2
im running a i7 2600K
Asus p8p67 pro
Geil 1600 value ram currentley running at 1333.
i have run a memory test which shows the memory is fine.
i have also updated the BIOS on the mobo to the latest version which is 1204
do i have a faulty CPU or motherboard?
i have been running this setup for a couple of days now and i havent received no BSOD or any other stability issues.
Thnaks
Matthew
i tried
Max temps show
core1 - 51
core2 - 51
core3 - 54
core4 - 56
then i run OCCT
occt
Asus p8p67 pro
Thnaks
Matthew
