STALKER Crashing
11 Apr 2003
Notts
Help please, cant play this game, it keeps crashing to desktop every 30 seconds or so, xfire gives this report at the same time...
<?xml version="1.0" encoding="utf-8" ?>
<ExceptionReport Version="4">
<Application Build="25831" Command="&quot;D:\Program Files\THQ\S.T.A.L.K.E.R. - Shadow of Chernobyl\bin\XR_3DA.exe&quot; "/>
<OperatingSystem Type="2"><Version Major="5" Minor="1" Build="2600"/></OperatingSystem>
<Exception Code="C0000005" Address="010EF48A"><Module Section="0001" Offset="0001E48A" FileName="D:\Program Files\THQ\S.T.A.L.K.E.R. - Shadow of Chernobyl\bin\xrCore.dll"/></Exception>
<Registers EAX="15DE4530" EBX="000015F0" ECX="0000057C" EDX="000015F0" ESI="00001C4C" EDI="152A4520" CS="001B" EIP="010EF48A" SS="0023" ESP="0783FDA4" EBP="00002134" DS="0023" ES="0023" FS="003B" GS="0000" Flags="00010212"/>
<BackTrace>
<Frame ProgramCounter="010EF48A" StackAddress="0783FDA4" FrameAddress="00002134">
</Frame>
</BackTrace>
</ExceptionReport>
The advice I got was to search through the official topic for my problems, but then I encounter spoilers :( Probably worth a try, at your own risk!
I fixed my Stalker crashes by a clean re-install of XP, updated graphics + sound drivers and bunging another 1gb of ram in.
One or more of those things fixed it, no idea which.
LoadsaMoney said:
Right click the Stalker icon, properties, and add the -noprefetch to the end of the target, as per here :)
Aye did not work, and for some reason stalker just turned off my extend onto second monitor option and left the monitor with a lot of corupted graphics on it...
Tried a few fixes from that site, altered loads of settings, updated drivers, even tried a nodvd thing as sugested in the main stalker post, nothing will work, reading on the of forums a lot of people with ati having probs, but most of them sorted them with the above measures :(
z0mbi3 said:
Coudln't say as I gave up on the game. It's not finished imho.
Aye sadly, but I realy want to play this, it looks good (Sat watching room mate) but so far I only find people with nvidia that have it working fine :(
Its been working fine on my rig with ATI. Perhaps uninstall the game, double check you have all the latest drivers in your system, and its all stable etc, then reinstall and repatch, incase something was conflicting.
Have updated to latest ATI Drivers, and reinstalled, still doing the same thing :(
Yeah i think patch 3 will have fixes for ATi cards, or they will be on the 2nd one, been that long i forgot as the 2nd patch was due weeks ago, but aint appeared yet and 3rd is now due, but bugger knows if the 2nd aint appeared yet, hopefully they'll roll both of them into one. :)
