Caporegime
10lb in 6 weeks?
have you put much body fat on?
Morba said:10lb in 6 weeks?
$loth said:Hey all,
What sort of repxset range would you reccomend I do for calf raises? I've been doing 1x12 1x10 1x8-10 increasing the weight on a leg press machine (like this one). Would doing it on a smith be beneficial?
Thanks for all the helps
Fusion said:I do calf raises standing with a barbell, but it's fine to do them on the Leg Press. I find that 3 sets in the 20-35 rep range work well. I tried three sets of 12-8 reps with a heavier weight but didn't find them as effective.
$loth said:Here are some current stats:
Arms: 12"
Legs: 20"
Chest: 37"
Height: 5'8"
Weight: 147lbs.
Styles said:If Cutting, post-workout you want to keep your fats to absolute minimum for the next couple of hours. Maybe irrelevant, but just a little advice
