Steering wheel locks
Used to have disklock, they are good but a bit bulky to store in the car when not using it
Currently have a Stoplock Pro Elite which is easier to use but less protection. The Pro Elite has more curve to fit over larger airbags
they are fairly cheap way to lower the chance of car being taken, will never stop it
I watched someone open a crap Chinese bike lock with just a hammer :D
They like using the cheapest metals availible.
It's called chinesium by some folks, a few of the bits for my miniature train are from China and the quality of the metal really is something to behold when trying to work with it.
I've used a Disklok on my Audi S4 since I bought it.
Just an additional layer of security, which I'm sure a determined scumbag could bypass, but every little helps I guess.
Depending on your airbag etc
