Man of Honour
- 5 Jun 2003
- Falling...
Neutral and handbrake. But I keep an eye on the junction so I can be ready to go well in time.
I slow using the brakes, then engage 3rd, then use the combined engine braking and foot braking together, then engage 2nd when I'm just trundling slowly - and do the same, then slowly dip the clutch all the way down as I come to a stop with the footbrake, pull up the handbrake, release foot brake, put it into neutral, release clutch, rest.
Sometimes I skip the down-shift into 3rd. It depends on the condition/type of road, and how abruptly I have to stop, etc.
I sometimes double clutch & heel & toe downshift because I find it immensely satisfying and it is a good way to show off, but I don't generally do that.![]()
Handbrake and neutral if I'm sitting still for more than about 5 seconds. Holding it in 1st puts unnecessary wear and tear on the clutch components.
No, but the release bearing will wear out faster, as will your foot
There's no need to do it. None whatsoever.
On my commute it is sometimes stop/start for entire dual carriageways. I just keep the clutch depressed and then lift to creep forward and depress to roll to a standstill. Sometimes I don't even bother using any throttle
Good luck doing a handbrake pullaway every 10 seconds for 20 minutes, which by your own self-imposed rules you'll have to do
Got 124k out of my last clutch before it needed changing so I feel I have the right balance of laziness vs being good to the car.
A leave it in "D" and put my foot on the brake, then when it's time to go I move my foot to the accelerator![]()
On my commute it is sometimes stop/start for entire dual carriageways. I just keep the clutch depressed and then lift to creep forward and depress to roll to a standstill. Sometimes I don't even bother using any throttle![]()
This type of journey would drive me insane in a manual. Autos remove 90% of the stress of driving for me. Clearly I'm getting old.
On the flip side, I would go bat **** insane in an auto. There's nothing to keep yourself occupied, at least a manual requires user input. Just having two pedals, go and stop, would make the same commute journey quite boring.
You must hate cruise control then.
All cruise does is saves you from having to rest your foot on one pedal, making slight movements now and then, it isn't like you would be doing anything with your feet in a situation where you would use cruise?
