Storage help / guidance please
10 Jun 2009
Darlington
Howdy.
I'm in a bit of a tight spot. I've finally finished my modded lian li v351 and I'm happy with the results but I've maid one glaring omission, my hdd's.
I've managed to get my ssd in for os and a few program's however my 3 hdd's ain't gonna fit:mad:
Totally my fault. My measuring sucks.
So how can I go about creating a storage solution for all my music, games, photos and videos etc.
Currently I've got bout 3tb of data that I can't access, whoops.
So what is NAS storage? How does it work? Any other ways I can use my data?
My disks are all random sizes from 1.5 tb to 500gb if that makes a difference to the route I take I don't know.
Any advice is greatly appreciated here
if you have a spare 5.25" bay you can buy a hdd dock that fits it,then you can plug in/out any hdd you need ect,they hook up internally to mb sata2/3 port,im using one myself
stardock are pretty good,plus it saves having to open up your case to fit/swap/remove hdd's just plug them in at the front
