Actually it is. My mechanic thought it is okay to leave it there as it is only moving the rod but nothing else. As you mentioned the blanking plates are fitted.
Remove the rod...
Thanks, thats a good idea!Usually you can get the swirl flaps mapped out which eliminates any issues with the mechanism all together.
The rod is no possible cause of the issue. The actuator, which moves the rod is.Remove the rod...
I have not thought of it. I have replaced the boost control valve as it seemed to be a possible cause of this intermittent power loss. I guess I should be able to see a fault in the diag regarding the faulty boost solenoid?It's not a boost solenoid issue is it? Due to modification i'll be replacing mine with a stronger/faster unit and it could be causing the bypass gate to open.
I mean the pressure converter under the intake manifold. As my power issues are intermittent, coming totally random, I don't think it is something with the vacuum lines.When you say boost control valve do you mean a pressure sensor? Or do you mean the map sensor?
If you have a boosting issue you need to check your vacuum lines first and foremost. For any splits etc
