Strange issue when no internet connection
15 Feb 2010
Either because i disconnect the Ethernet / disable networks / or the router needs rebooting my PC acts very strangely when booted. The PC kind of just stalls for 6 minutes every time. I can play a video/music file but windows functions don't work, they just freeze. Thumbnails and folder icons don't get created they just stall and my logitech mouse configured button don't work.
Anyone know what this is all about. Could it be something to do with postgres or VMware, these are softwares i have that are not on my other dual booted system where this does not happen
Thanks for the help
try putting windows folder options back to default. type folder options in start menu to open it up and reset to default on all tabs , and run sfc /scannow in command promp running as administrator
Iam not connected to any network drives
sfc /scannow is thew same as disk check no? I am using an SSD, though i had the issue with my raptor to; so i wont do disk check since its bad for an SSD i heard
