- 10 Dec 2020
If you have had it past POST and into Windows then the RAM not being on QVL is very unlikely to be the issue. Remember that not being on the QVL does not necessarily indicate any compatibility problem - it might simply mean that it did not make the test list (i.e. simply a matter of Asus QA resources).
The part that interests me is that you state that there is 0% repro when there is a monitor attached to the iGPU. But with the iGPU disabled there is still a repro, which is at POST. That indicates a possible problem at dGPU BIOS load. Are you certain that the SBIOS BAR allocation is correctly set?
I still haven’t got round to giving ASUS a call yet as they may have had this before with this board & know an easy solution but I know that as soon as they discover the RAM isn’t QVL, they will blame that so will wait until then & see.
