forget that stick its just to make money...buy one of these instead...these sticks will work with anything including thje legendary mame!
You can customise these sticks also,i have had one of thses for 3 years and ist rock solid..i use it on mame a lot an on tekken on the ps2
http://www.xgaming.com/two-player.shtml
probably one of the best arcade gaming sticks in the world
I am sure it is great as it is a quality piece of hardware. Sadly to get it to work on PS3 you need to buy 2 separate adaptors (totaling in excess of 50 dollars for 2 player) and there is no Xbox 360 support.
So pretty useless for Street Fighter IV support tbh, imo. Also no buttons specific to consoles means you will possibly have to use a 2nd controller to access some menus, which is far from ideal.
so what format are people getting?
I have more friends on xbox but the pad is rubbish.
Playstation 3. As mentioned the pad on the 360 is crap, plus I have a PS3 Hori stick. Unless you have a joystick or a group of friends who do not mind playing the best beat em up on the planet with the worst possible controller, buy the PS3 or the PC version imo.
All the sold out joysticks are a bit annoying tbh. I cannot believe they have not made enough to supply demand
(They are overpriced too, but that is another issue
rp2000
