Well, this thread makes for pretty depressing reading.
Speaking personally, I certainly can't conclude that the Striker-E is worse than any alternative 680i board.
The original EVGA was terminally flawed (SATA related data corruption) - the A1 revision supposedly fixed this and other minor issues, though EVGA's forums are still chock full of foam at the mouth rants!
I had an MSI-P6 diamond, worked fine for 2 weeks, then inexplicably froze during posting and utterly ceased to function thereafter - never once over clocked or overvolted.
Also tried the Gigabyte N680-DQ6 - memory hopelessly unstable at stock (modules worked without issue in other boards) and no way of manually altering the timings - sent back within two days.
As for the Striker, got one when it was released over a year ago - initially had problems with the x-fi (crackle pop etc etc) fixed via a BIOS update.
Worked brilliantly for four months and throughout hours of gaming (x6800 dual core/8800gtx SLI/4gb 800mhz Corsair at optimal 3-4-3-9 timings). Stupidly managed to drop my system on the floor (carpeted but hard) during a weekend of tinkering, still worked!!
Switched to a quad core chip (qx6800), still worked (4x sp2004 large fft/Blend for 20hours) and tons more gaming.
Finally ran into the notorious CPU-INIT problem when swapping power supplies (Enermax too noisy, wanted a quieter one). Tried all suggested remedies (swapping memory, 1 stick, different CPUs etc) no luck.
Ordered and fitted a new board (another Striker). Initiated an RMA for the "faulty" one, had the form ready to fill in but decided to leave the board unwired with "Clear CMOS" button pressed in and battery removed overnight, simply out of curiosity.
Tried it the next morning....would you believe...BACK FROM THE DEAD! Ran a gamut of tests (memtest multiple passes/games/sp2004 etc) stable as ever. Too late to send new board back, so sold old one on the bay instead.
Moving on...new Striker as solid as original...until...I decided to replace the memory - which I'd been using for a year but now needed for another system.
Wanted to get the same type (Corsair TWIN2X2048-6400C3), but this had been discontinued, so I had to settle for the closest match (Corsair Twin2X2048-6400C3DF) the same part (so I thought) but in "dominator" form.
To cut a long story short - too late!! - I'd have been better off sticking with the old memory in the Striker and installing the new (which required between 2.3 and 2.4v to operate at stock spec) in the secondary system.
It would appear the board's Achilles heal lies in its tendency to "chew up" memory when any voltage above 2.3v is applied (with or without active cooling). Evidence suggests this issue is manifest in all 680i boards and is not specific to the Striker, though it has been discussed in detail on Asus's forum. In my case, it took 3 fried sticks of memory before I was able to pinpoint why the board had suddenly started to behave so erratically!
Subsequently RMA'd the RAM and acquired two new pairs of Team Xtreem
3-3-3-8 PC2-6400C3 - all but identical to the original "non-dominator" Corsair and happy at 2.25v - system has been rock solid since.
So in conclusion - to anybody using, or planning on using this board, proceed with extreme caution when it comes to memory. If the spec necessitates any voltage above 2.3, best to give it a miss, especially if you are set on having 4 sticks. Moreover, if anything above 2.2 is required - in any scenario - I'd strongly advise that you invest in one of these, indeed, I'd almost insist on it:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-123-CS&groupid=701&catid=57&subcat=399
The Striker ain't no saint, but when considering its origins and direct competition, I can't help but feel that Asus made a pretty good showing.
