Right then, I'm going to try these settings for a small increase to my current OC and hopefully achieve 3.20Ghz:
FSB: 1424
CPU Multi: 9
Vcore:1.45
Memory:2.05
1.2v HT:1.60
NB Core:1.45
SB Core:1.60
CPU VTT:1.40
RAM @ 5-5-5-18 / 2T
My aim is to have voltages which are clearly too high for an OC of 3.20 therefore lowering the chances that my voltages will have an affect on stability. The RAM timings are loose and I know they work at this because when everything is on Auto, those are the settings which CPU-Z reads. Hopefully this should eliminate a lot of variables so I can just alter the RAM divider and see if that helps me get stable.
Anyone have any suggestions as to what MEM DDR, Mhz settings I should try (my RAM is Corsair XMS2 6400C4)? Or should I just start at something like 600 and move up in increments?
