My mate asked me to sort his pc out, hes always getting viruses from dodgy sites and normally i sort it out no problem.
This time he had loads of viruses and i thought id sorted the roblem by virus scanning and deleting the infected files which were showing as cookies, there was also a program called newdotcom or something like that which was causing most of the problems with viruses, so i was able to uninstall that with an uninstall file within the folder, but the .dll file wouldnt delete, ive downloaded a prog to remove the .dll file and will use it tomorrow
but..
The pc is stuck in safe mode, ive tried everything to get it into normal windows mode, presses f6 i think and selected normal windows boot and it just went back to safe mode again..
Any ideas ?
thanks
but..
Any ideas ?
thanks
