Permabanned
- 15 Dec 2008
So the Arctic Cooling F12s arrived. Installed them (twice cause I forgot how to cable manage) and set them to about 1000rpm. Just as quiet as my old fans but holy bawls have the temps dropped. So last night I was getting around 47C water temps and now it is 38C.
Is this now low enough? GPU is just stupid cool at 42C and CPU temps are maxing on the hottest core at 62C.
Only you can decide if those temps are good enough, run the fans at max speed and see if the temps drop even more.
And if they do drop even more you can then decide if the extra noise generated from running the fans at a higher RPM is worth the lower temps or not.
And told you the problem was with your loop
Also told people those Noctua fans just flat out suck and are over priced, over hyped tosh....
