- 5 Sep 2011
- Surrey
ok so theres a lot of replys thanks. cpus vcore is 1.440 if that helps, the gtx 560 vram is 1gb. i had this issue with a single gtx 560 thats why i went sli but its the same. ive ran it all on stock clocks with 1 card and still lagging . theres no other pci cards no wifi. im only on campaign mode in games, so not internet lag. if i up the vcore to 1.5v would it be ok? it was stable in prime 95 at 1.440v.
Too high. 10-20mv increments. Prime is a synthetic test it doesnt stress the PCI bus in any shape or form like gaming does
I've used that card on a similar system with medium detail. Should be possible to play without stutter. Maybe try at stock first (on cpu, if you haven't already).
I would also try updating to latest drivers if that hasn't been mentioned as Bioshock Infinite had stuttering issues on earlier drivers.
If it's ONLY dropping to low 20s and not an actual stutter as Greg suggests it could quite easily be the cards just arent up to it. But I know I've played BF4 ok on a similar rig
