- 24 May 2011
Hi All,
I wouldn't mind some help picking the components for a sub-1k system.
I already have a Corsair 600T case and a 27" Hasro screen so they don't factor into the cost.
I'm not a high end gamer by any means (more of a 360 fan!) so it doesn't need to play games at the highest possible settings.
I do a lot of design work though, Photoshop, Adobe Creative Suite, and a bit of 3D Studio Max.
So i was looking at 16gb memory as the amount of layers and/or polygons i work with slows my old pc down to a crawl.
I wanted to get SATA-3 components if possible so it's more futureproof, USB3 etc.
Also i'm not unsure whether to go for Core i5 or i7, but if overclocking is as easy as it sounds on here i'll probably do that.
One of the main factors for me is that the system runs cold/quiet!
Thanks!
Ryan
Thanks!
Ryan
