I've got a svs SB ultra 13. Good sub but I'd like to upgrade and get duals
Not much choice for high end big subs in the UK, and going to be expensive. rythmik and jtr also if you're ok with importing
S3612 is a good sub, but you may want to consider duals to get a flatter response.
There's the ipal versions also.
Personally I prefer sealed box subs, and two good sealed box subs will be plenty..
If you're the same guy on avforums, you don't need two monster subs in that size room, I ran a single svs SB ultra 13 in a similar sized toomy and it was superb. And in that room size, sealed will be better.
Running the svs sbu13 paired with svs sb12+...not ideal two different subs but having second does help...but now in a room three times the size.
I had a svs pc ultra 13 in similar sized room as yours and it didn't sound great, for music.
Do you already have digital room correction in place to deal with room nodes? If not, then I'm going to suggest that you do that first. It was easily the biggest improvement that I made to the bass in my system.
As an example, my lounge has a node at around 38hz of above +10db, with a secondary at 76hz of around +5db. From experience, there's simply no getting around that, short of either having speakers that don't go that low, and I found that integration with a sub nearly impossible. With DRC in place, I now get a very smooth transition between my main speakers and sub.
Will do it this week!If you already have a mini dsp, I’m assuming that it’s just a question of setting it up and using it.
Sorry, don’t know much about the unit.
Sweet!70 cubic meters
Another option is dual s1512. Dual 15" may be better than single 18", flatter response. Cone area also.
Did you get two ?
Pros and cons of sealed, and ported...
Two subs will be better than one.
Ipals are getting good feedback...but even more expensive.
I can't justify £4000 on subwoofers
