Get two subs its so good. Never going to have just one again.
Doubt it. Will do a review of it and list parts used but that’s about it.hoverboss = hilarious. Are you going to be posting a build log?
Two subs is so effective double cream smooth.
Ideally you want a av amp capable of dual sub eq and calibration not just dual mono out.
Need to use REW to get best place also
Just a question. You appear to be considering spending a good deal of dosh on more speakers, yet you're running a mid-range AVR.
Might be worth looking at options amongst a good pre-pro combo.
Haha, I am already in the market for an Emotiva or NORD amp.
Just waiting for the right deal to come up as I'm not in a gigantic rush at present but I do agree with you, its something I need to get sorted eventually.
My front 3 could definitely do with it.
In terms of pre, I'm not willing to jump until a device which as at least 2x HDMI 2.1 inputs (one for my PC and one for my future PS5.. and maybe one for my future XBOX) is available as I know I'll have have to upgrade again.
Also I am moving house in the next year so I'm not sure how many channels I will end up needing, hence I am waiting as I might try to expand from 5.1.2 to 7.2.4.
The issue is that as much I do love sound, splashing for the 'final' sound upgrade of HDMI 2.1 AVR, power amps and 2-4 more channels will probably stretch me 5-7k, and that should be in the JVC NX7-mark2 terrirtory, which is what I'll likely go for instead.
Stop mucking around and get a Trinnov
I'm edging towards an emotiva xpa gen 3 or something from nordATI 6007?
I wouldn't buy emotiva. I'm using ATI 2000 series. I'm looking for a new av pre, still using non hdmi, Dolby digital/dts 7.1 av pre, new ones are either buggy, or just too expensive...and out of date so quickly with hdmi spec.
I run my BKs dual mono using antinode it sounds integrated just fine.
