Such low frame rates.
Just loaded up Euro Truck Simulator, looks to be exactly the same game and I was getting a solid 60FPS(Vsync on and don't know how to turn it off) with the game a full 1080p and 8xAA everything max.
Might be worth seeing if Euro Truck Simulator makes any difference, might be a bit hard to get hold of mind.
Why is yours working and mine not then? :(
I really like this game too.
I did it.
After all, I'm going to have to fit my new graphics card and PSU when it arrives.
Made no difference. :(
I CHANGED MAXIMUM PRE-RENDERED FRAMES to the highest setting though and I think it has made a marginal difference.
Maybe when my GTX 460 comes it will be OK.
I did ask for my order to be cancelled with this other company, but they said it has already been sent out. Hope it all goes smoothly as the reviews made me want to cancel, but not possible now.
Fraps causes lower framerates on even my system...
I find disabling some of the processor cores makes it run quite abit better.
If your CPU has multipul cores
while fraps is running, go into task manager, click processes, right click on fraps.exe and click set affinity, I dissable all cores apart from CPU 3 (the 4th core on my cpu)
dissable all cores apart from 1 of them and click ok,
see if that helps...
