Glad to hear that the power was manageable. Get it undervolted. Hope you solve the other issues and don't need to ditch it.
It should appear as a red square icon when you type AMD or Adrenalin in the windows search bar. I find the software fine vs the Nvidia control panel/geforce experience apps.
Indeed, but the system was unstable; maybe it has to do with the limited resources of PCIE bandwidth, as my HP PC has an M.2 SSD, so it shared the same bandwidth because the apps I tried opening were not responding. Correct me if I'm wrong.
I think I would be a lot better off just getting a new motherboard and a new case/PSU and moving everything from my HP to a new system so that I can have more choice in selecting a better GPU, but for PCIE 4.0 support, it would mean replacing 5700G with something better? Honestly, I don't know why some companies like to scale back/cut down on the PCIE bus, especially with GPU and CPU. It is pretty pointless to move to newer technology yet cut back simultaneously.
EDIT: There was no red square or Adrenalin app icon when I typed in the search bar, which is why I think it may have to do with issues with PCIE on M.2 SSD. I don't know, but I returned the GPU card as it was not worth troubleshooting on a restricted HP system.
