Because the description of "sliding bush or gland" points to the bush that supports the damper rod at the top of the strut body. i.e. the bit the damper rod slides in and out. Dampers have oil in them, if the seal at the top starts leaking (say, due to a worn out bush) then the oil will leak out.
The strut top mount is nowhere near the top of the strut body?
u mad bro?
Do you know what a strut top mounting is?
Quite familiar. I'm interested by what measure are they nowhere near the top of the strut body? Top mount bolts directly to the top of the strut. I would consider the strut to encompass everything up to the top spring cup. Even if you were being peculiar and talking about the top of the damper body, that is what, 6 inches away. The only thing closer than that is the turret itself![]()
Really?
So, you are cool with sharing the road with cars on dodgy suspension, steering and brakes then?
Stay confused by all means. OP, it'll be fine...if you hear any knocking from the arb bushes then by all means get it sorted...still sounds like the tester is being picky with the strut top mounts though...
The item I am talking about has nothing whatsoever to do with the top mount, why do you insist on going back to this?
I'm presuming you have absolutely no idea what a 'gland' is (besides the things in you neck and armpits that feel painful when ill)? It's a seal, that allows linear or rotational movement between two parts whilst preventing the flow of liquid, e.g. oil. Exactly where in the top mount do you think a gland would be used?
