Anyway a good motorway blast like that should be good for your car, should reduce the need to terraclean the car.
[TW]Fox;25304126 said:I don't think they broke as a result of that journey at all.
Yes. and No. If you sat at 30MPH in 1st gear bouncing off the limiter and sitting at 140 mph bouncing off the limiter, the engine would be under the same amount of load.
As far as I understand it this isn't correct, due to gearing and aerodynamics and the quite ridiculous levels of drag that will be created at 140mph, therefore, ignoring the engine speed, it'll be under a much higher load at 7000rpm in top gear at 140mph than it will be at 7000rpm in 1st gear at whatever speed that translates to - 30-40mph for example.
Someone please correct me if I'm wrong though.
[TW]Fox;25302658 said:I did 155mph in my car last year and it didn't explode whilst doing it.
badman
badman
I also have no doubt that the suspension components, the turbos, the oil, the fuel pumps/system, cooling system and tyres would wear out much quicker as a result.
Why?
I've done 148mph in my car and it didn't blow up either.
[TW]Fox;25304860 said:What's bad about it? It was on a derestricted German autobahn so.completely legal. That's not a bs cover story either - it actually was.
Given that high speed will be on the motorway, this will wear suspension components slower than a blast down a country road
same for tyre wear
and since the car will be going quicker cooling shouldn't be an issue.
