- 18 Jun 2010
- London
OMG just noticed that 950W Corsair TX950W is not modular plant. so will have big mess. Is there equivalent module psu please? thnaks
Stick to air, water is a needless complication and takes up space in the case.
If you were talking about normal water cooling set ups I could understand. But in relation to 'all-in-one' CPU watercoolers that sounds like a load of tosh to me.
The Antec Kuhler and Corsair H50/H70 as well as the e-coolIt are all easy to install and take up less space than a lot of air coolers. Not to mention they're often quoted to be quieter.
Guess who bought a Delta fan as their first ever PC fan purchase because they thought moar RPM and moar CFM = leet?
The Antec Kuhler 620 takes up a tiny amount of space, plus it gives you lots of clearance for large ram modules:
http://forums.overclockers.co.uk/showpost.php?p=18940759&postcount=1116
Plus its better than a Corsair H70 with a second fan installed, and its <£50.
True it doesn't look too shabby. Still, you just don't need the 5 degree's less or what ever it is.
You will want to make sure your SATA cables are SATA3.0 too, as the copper inside is more coppery
The fact of the matter is you are still dealing with water and still have a separate pump to install somewhere etc etc. It is most certainly more hassel than an air cooler and totaly not needed. They barely show any increase in performance and just cost more than is needed to spend.
2 x 480s will draw up to 630W's so need powerful PSU
http://www.geeks3d.com/20100414/power-consumption-of-two-gtx-480-in-sli-with-furmark-and-3dmark03/
So now I only got memory to choose and may be sound if on board is not good enough.
The G Skills I posted earlier are the best choice.
For 2x4 Gb, got for either the Cas 8 1600, or Cas 7 1600 Mhz ones (blue or black heatspreaders) based on whether or not you are willing to pay the extra.
Well that logic somewhat stumbles when it comes to those heat sinks which require fans to be fitted and/or extra's to be added on to get them to work. That's hardly much difference in effort compared to putting four measly screws in place.
And it's hardly hassle. There are literally dozens of vids online demonstrating how easy it is to install. Hassle would denote its going to be a royal pain in the backside to install. The reviews and videos speak differently.
And you might still be dealing with water, but they nevertheless do all they can to make them safer. Such as the Kuhler for instance using a non-corrosive chemical instead of water.
Valid SB systems tend to be cooler anyway so in most cases it's just not necessary when a £20 cooler will suffice. But if you need the space and/or you have a processor that gets pretty hot, as with what bhavv says, use the push pull system on them and they're as good as the the NH-D14
Its a few degrees better than a £80 cooler though, thats what makes it special.
