System Reserved showing?
9 Jul 2009
I have 2 WD HD -WD1600AABS and WD2500AABS.
Both are showing there system reserved partitions, is this right and can I turn this off?
Showing where? My Computer, or Disk Management? And when you say there, do you mean their or they're? How big are the partitions?
Showing in my computer, they are around 200mb. The second drive does have W7 installed, but is not a primary drive.
If you've installed Win7 with the other drive still plugged in, funny things can happen. Anyway, just go to Disk Management and remove their drive letters and they'll no longer show up. Unless you can figure out which one is the System Reserved partition for your current Win7 install, thus enabling you to remove the extra one, just let them be - they're not big enough to worry about!
